vincentvallez
Sep 15, 2014Aspirant
[Solved]Problem with Wake On Lan and Scheduled power on/of
Hi, Actually I've got a readyNas 104 with three harddrive (2to + 2to 3to). My problem is when I activate the schedule power on/off the readynas didn't power off. It is still on. And the seco...
vandermerwe
Sep 15, 2014Master
The only problem with setting just 1 hour on is that if you're not using the NAS it will power on for 1 hour.
You could perhaps use this hour to do automated backups?
I did say hopefully the power timer will be improved, it may not be of course.
As far as WOL goes, I use this:
http://wol.aquilatech.com on a windows PC, and the Fing app on my ipad.
