FatGaz
Oct 26, 2013Aspirant
SOLVED**ReadyNAS Duo v2 growing permissions problem
Hi All, I was a very happy Duo v2 owner up until yesterday. I used my duo to serve up a large film collection for an HTPC, run squeezeserver with 400GB music and store backup items for general file...
FatGaz
SOLVED
Running back through any changes, I noticed that my Apple Airport Extreme had also updated to version 7.6.4 It appears that this version of AAE causes one or two network problems regarding access and logins. (Apple forums)
The rollback of my router now means any device can connect, no denied access or login required.
Changes to the settings actually take effect. Duplicate share entries have all gone and otherwise hidden files have disappeared too. File and folder modification can also take place.
In the end I downloaded Apple airport utility 5.x for windows xp and used the upgrade firmware route to remove the new and go with the old. Result, almost everything has reurned to near normal!
