KenTanker0us1
Feb 06, 2018Tutor
Some advice, please, on proper setup of static IPs
Hello friends, I have returned to my favorite forum for some good advice about static IPs on my network. I've done some studying and some tests and I understand how to set static IP on my NASs (plur...
Feb 07, 2018Guru - Experienced User
Some routers use different names (ARP Binding is one).
What router do you have? If you have a link to it's manual, include that too.
KenTanker0us1
Feb 07, 2018Tutor
I have an EnGenius Wireless Router ESR350. Manual here:
https://www.engeniustech.com/resources/ESR350_Manual_061813.pdf
In studying whether I could reserve an IP I came upon this:
..and so I tried it. I've got the entry in the Static DHCP Table. It also shows up in the DHCP Client Table above. So it's in both places. I just added the IP the NAS already had to the Static DHCP Table. Did I do it right?
many thanks
Ken
- StephenBFeb 07, 2018Guru - Experienced User
Yes! Their "static DHCP IP" is the same as Netgear's "Reserved IP address". Now your NAS should always be assigned the same IP address.
- KenTanker0us1Feb 07, 2018Tutor
Excellent! Thank you StephenB, great results so far. Now please, for my education, I would like to ask/verify:
1. One thing I do when I lose internet, or have massive network problems in general, is this: I power everything down, and start it up from bottom up. Cable modem, router, first set of switches, second set of switches, NASs, license server/render manager, then all the machines. If I have to do this, will these IPs be saved?
2. Can I assume then, this works for every machine/printer I have? So I don't have to worry about it again?
Thank you so much!
best
Ken
Well, I went ahead and did both NASs, 1 printer and 6 machines. It seems kinda strange that the Static DHCP IP Table limits the number you can reserve. But everything seems happy so far. Thanks very much!
best
Ken
