BigRedDog
Jul 20, 2010Aspirant
Something wrong with the volume's CNID DB using temporary DB
Brand new Pioneer Pro, with current firmware (4.2.12). Put data on the share - seemed OK. Logged into share via my Mac and got the following message immediately... "Message from server <server na...
goinup
Sep 01, 2010Aspirant
Hi-
I am also seeing this on my NAS. I recently upgraded to the latest 4.2.13 and did a Factory Reset. I can access the /* but if I try to view /media/*/ then the Finder will hang. This is true for all 3 Bonjour services (AFP, CIFS, etc).
I am using a ReadyNas Pro with 4 disks. A quick snippet from the afp.log:
I can access the SMB share via the Go To (command+K) in the Finder and entering the IP address of the NAS. Also, in daemon.log I found:
This leads me to believe that this is due to bonjour broadcasting services on an invalid hostname. I have, as part of the Raidar setup process, set the hostname for the NAS to readynas. nas-EA-42-F9 was the original hostname.
Any thoughts/feedback would be greatly appreciated. If support is interested in the rest of the logs, just let me know where to send them :)
Thanks
Sep 01 23:11:09.457771 afpd[7958] {volume.c:1850} (I:AFPDaemon): CNID server localhost:4700
Sep 01 23:11:09.994624 afpd[7958] {volume.c:1850} (I:AFPDaemon): CNID server localhost:4700
Sep 01 23:11:12.468497 afpd[7958] {volume.c:1850} (I:AFPDaemon): CNID server localhost:4700
Sep 01 23:11:25.893833 afpd[7958] {cnid_dbd.c:325} (E:CNID): dbd_rpc: Error reading header from fd (db_dir /c/media): Resource temporarily unavailable
Sep 01 23:11:47.352737 afpd[7958] {cnid_dbd.c:325} (E:CNID): dbd_rpc: Error reading header from fd (db_dir /c/media): Resource temporarily unavailable
Sep 01 23:11:47.352881 afpd[7958] {cnid_dbd.c:411} (E:CNID): transmit: Request to dbd daemon (db_dir /c/media) timed out.
Sep 01 23:11:47.352909 afpd[7958] {file.c:246} (E:AFPDaemon): Reopen volume /c/media using in memory temporary CNID DB.I can access the SMB share via the Go To (command+K) in the Finder and entering the IP address of the NAS. Also, in daemon.log I found:
Sep 1 17:31:50 nas-EA-42-F9 avahi-daemon[3519]: Service "ReadyNAS Discovery [nas-EA-42-F9]" (/etc/avahi/services/readynas.service) successfully established.
Sep 1 17:31:50 nas-EA-42-F9 avahi-daemon[3519]: Service "FrontView on nas-EA-42-F9" (/etc/avahi/services/frontview.service) successfully established.
Sep 1 17:31:50 nas-EA-42-F9 avahi-daemon[3519]: Service "nas-EA-42-F9 (CIFS)" (/etc/avahi/services/cifs.service) successfully established.
Sep 1 17:31:50 nas-EA-42-F9 avahi-daemon[3519]: Service "nas-EA-42-F9 (AFP)" (/etc/avahi/services/afp.service) successfully established.
Thanks
