BigRedDog
Jul 20, 2010Aspirant
Something wrong with the volume's CNID DB using temporary DB
Brand new Pioneer Pro, with current firmware (4.2.12). Put data on the share - seemed OK. Logged into share via my Mac and got the following message immediately... "Message from server <server na...
goinup
Sep 02, 2010Aspirant
@skywalker
I unmounted the AFP share and mounted the CIFS share. When I tried to view Media/Videos/* the Finder hangs and I can't even list local folders! I am forced to relaunch the Finder to get things working properly.
Digging through the logs (not sure why I didn't see the smbd logs earlier) I think it might be related to:
I then went into Frontrow to verify the share settings. The settings for this share are as follows:
default access: 'read/write'
allow guest access: true
Automatically set permissions on new files and folders: true
group rights: read/write (times 2)
every rights: read/write (times 2)
Enable Locks: true
Basically, default stuff.
Any thoughts? Am I on to something?
thanks!
smbd version 3.5.4 started.
Copyright Andrew Tridgell and the Samba Team 1992-2010
[2010/09/02 18:56:43.348820, 0] smbd/server.c:281(remove_child_pid)
Could not find child 2200 -- ignoring
[2010/09/02 18:56:43.349256, 0] smbd/server.c:281(remove_child_pid)
Could not find child 2203 -- ignoring
[2010/09/02 18:56:46.688989, 0] smbd/server.c:281(remove_child_pid)
Could not find child 2284 -- ignoring
[2010/09/02 18:56:46.689487, 0] smbd/server.c:281(remove_child_pid)
Could not find child 2287 -- ignoring
[2010/09/02 18:56:46.713178, 0] smbd/server.c:281(remove_child_pid)
Could not find child 2295 -- ignoring
[2010/09/02 18:56:46.713645, 0] smbd/server.c:281(remove_child_pid)
Could not find child 2298 -- ignoring
[2010/09/02 19:10:15.422436, 2] auth/auth.c:314(check_ntlm_password)
check_ntlm_password: Authentication for user [GUEST] -> [GUEST] FAILED with error NT_STATUS_NO_SUCH_USER
[2010/09/02 19:11:36.794493, 2] auth/auth.c:314(check_ntlm_password)
[2010/09/02 22:23:01.437042, 2] auth/auth.c:314(check_ntlm_password)
Enable Locks: true
thanks!
