Christopher_Man
Jul 08, 2013Aspirant
Sorry, I teach Aristotle, So I'm stumped
Symptoms: Readynas Duo 3.5 years old Turns on and off properly, but delays on both up to 60 seconds Blue light flashes. Green light steady on Disk I; flashes on disk II (I have removed Disk I...
Christopher_Man
Thanks. Disk I is removed and Disk II is in and Raidar Connects.
Volume status is blank
I get two green lights under "disk status" (again, only Disk II is in)
I also get a "corrupt root" message under the "i" with a circle around it ("firmware revision status")
And this message about firmware:
A newer version of the firmware for your ReadyNAS device is now available. To install it, please go to the System page and click on the Update tab. Then, go to the Remote tab, click the Check For Update button, then click Perform System Update.
However, I cannot get the browser to open the Front View Wizard to access the "system page" for the firmware update
Note: while Raidar can find the ReadyNas, it doesn't yet appear on my PC's "Network" (Windows 2010)
