Northwinds
Jul 04, 2011Aspirant
sparsebundle problem-unable to mount - OSStatus error -6602
Okay - Hi all, A few weeks ago my Timemachine backup stopped working and i couldn't access the other files on my ReadyNAS Duo either. Long story short, disk 1 had failed. Managed to get the mirrored...
mdgm-ntgr
Jul 18, 2011NETGEAR Employee Retired
Northwinds wrote: when I log on via smb through finder there is a folder called iMac.sparsebundle
What share do you login to via AFP.
Northwinds wrote:
it cannot however be mounted - in fact the error message is"The operation cannot be completed because the original item for iMac.sparsebundle cannot be found"
You can't mount a sparsebundle over CIFS, only AFP. This may not be the problem here.
Northwinds wrote:
In addition it can't be seen when I go in via SSH either.
It will be there, you just don't know the path. It may be somewhere like /c/home/admin. If you look in the /etc/passwd file you will see the location of the home share for the "admin" user (If that's the share in which the sparsebundle is stored).
Northwinds wrote:
In addition, I'm noticing that when I enable Timemachine in frontview it still has the 0GB of Max 741GB Capacity showing, even after i change it an apply, hitting refresh takes it back to 0GB again.
You can try clearing the web browser cache (e.g. Safari > Empty Cache). Also I have some useful commands giving info regarding Time Machine on the ReadyNAS listed here: http://www.readynas.com/forum/viewtopic.php?f=18&t=42033&p=239030
The repquota command will tell you the quota for the ReadyNAS Time Machine user and conclusively tell you if it's set to what you want it. On one platform you need to use grep "text" for the code after the "|" separator on that line and on the other one you need to not use quotes.
