Northwinds
Jul 04, 2011Aspirant
sparsebundle problem-unable to mount - OSStatus error -6602
Okay - Hi all, A few weeks ago my Timemachine backup stopped working and i couldn't access the other files on my ReadyNAS Duo either. Long story short, disk 1 had failed. Managed to get the mirrored...
mdgm-ntgr
Jul 25, 2011NETGEAR Employee Retired
Northwinds wrote:
nas-07-C5-4C:~# repquota -as | grep limits\|User\|ReadyNAS
Block limits File limits
User used soft hard grace used soft hard grace
Ah, I think you need to use
nas-07-C5-4C:~# repquota -as | grep "limits\|User\|ReadyNAS"
Northwinds wrote:
nas-07-C5-4C:~# cat /etc/passwd | grep ReadyNAS
Please don't publish the output of this line publicly.
Northwinds wrote:
nas-07-C5-4C:~# ls -la /c/.timemachine
ls: /c/.timemachine: No such file or directory
O.K. So you're not using the supported method.
Northwinds wrote:
<txt-record>sys=waMA=XX:XX:XX:XX:XX:XX</txt-record>
</service-group>
I don't think I'd post this line either.
Northwinds wrote:
Hope this makes some sense to you?
Yes. Please try the repquota command again using the quotes this time.
Please also look for the sparsebundle, perhaps look under /c/home/admin and see if you can find the sparsebundle there.
If so, try doing
du -csh /c/home/admin * and post the line that mentions your sparsebundle.
