domquark
Jan 19, 2017Aspirant
specified ou does not exist in the domain
Hi, Urgent help needed! After an upgrade from 6.4.x to 6.6.1, I now cannot get the ReadyNAS to talk to AD! All I get is the message "specified ou does not exist in the domain". I have tried all c...
- Jan 27, 2017
I have eventually solved the issues that I have had.
If anyone has had similar issues, upgrading to v6.6.1, this is the only way that I found that worked:
1. Backup all data off NAS
2. Write down your configuration (don't bother saving it - see below)
3. Wipe the NAS using the power button/reset button method - do NOT use the web interface to wipe - it does not seem to do it properly
4. Manually rebuild your configuration. Do not use the config backup, as it makes the system unstable and you'll have to wipe it again (it certainly did in my case). It would appear that a config backup may not always work [on rebuild], and may carry across errors or instabilities or may be just incompatible with the newer firmware.
I hope this helps anyone with the same problems.
domquark
OK, after managing to perform an OS reinstall, I have managed to get back into the NAS. However, it looks like 6.6.1 has really messed things up, as I still have the following issues:
Users still cannot access all the shares
I am unable to run a configuration backup
I am unable to configure more than 1 NIC (I previously had all 4 bonded together)
I am unable to change the admin password
I am unable to enter email details for alerts
Monitoring has really gone pear-shaped -
I now have 3 fans labeled Fan 1!
Four sensors are showing crazy levels:
AUXTIN3 = +107°C
PCH_CHI = -13°C
PECI = -77°C
(And my personal favourite) AUXTIN0 = -128°C!!!!!!!
I'm guessing 6.6.1 is not the best update and I'm going to have to reset to factory and rebuild. But can someone tell me if I can rebuild with an older version?
bedlam1
Jan 19, 2017Prodigy
Did you perform a manual re-install firmware after downloading OS 6.6.1 and unzipping it from HERE or a Boot Menu OS re-install
The manual method may be best IMHO
- domquarkJan 19, 2017Aspirant
Hi Bedlam1,
Thanks for the reply. I did a Boot Menu OS re-install, but I may as well try a manual install. Hopefully it will let me, as many things don't appear to be working, but I'll give it a go and get back to you.
Hi Bedlam1,
I have tried an OS reinstall, the manual way.
I cannot tell if it has fixed the user access issues, but it has fixed the monitoring (1 down thank you!)
But I still cannot take a config backup, get email alerts to work or change the admin password.
Alas, I'm offsite now, but I'll check the user access tomorrow. It's a bit worrying that so much damage can be done with one update, and it would seem that I'm not the only one with issues with 6.6.x versions.
Out of interest, is there a downgrade path without wiping the whole system and starting again?
- bedlam1Jan 19, 2017Prodigy
Best wait until a Netgear Mod comes by or someone more savvy than myself.
I have been using 6.6.1 for weeks now (beta versions) and it has not been too bad, admittedly only on a home Pro 4.
I am guessing that somehow your original upgrade got screwed in it's passage from Netgears server.
Netgear warn against downgrading, what the implications are I don't know
Best of luck
