clingon
Sep 01, 2014Aspirant
Speeding up data transfer?
My ON NETWORKS PL200-199UKS 200 Mbps Powerline (connected a D-Link DSL-3680 router) is feeding a tp-link tl-sg1008d gigabit Ethernet switch, which is hooked up to my Lenovo i7 3770 3.4ghz 16gb PC & NV...
mdgm-ntgr
Sep 01, 2014NETGEAR Employee Retired
Are these your write speeds?
For your NV+ (v1) units about 10 MB/s is what you'd expect for write speeds.
The NV+ is using hardware from early 2006, so the hardware is quite old.
A newer ReadyNAS may perform better. Though using a 200 Mbps Powerline adapter the performance you'd get might not be much better (200 Mbps may give you up to around 20 MB/s, but due to various factors your performance may be less). Cat5e or newer ethernet cables are better than ethernet over power.
