clingon
Sep 01, 2014Aspirant
Speeding up data transfer?
My ON NETWORKS PL200-199UKS 200 Mbps Powerline (connected a D-Link DSL-3680 router) is feeding a tp-link tl-sg1008d gigabit Ethernet switch, which is hooked up to my Lenovo i7 3770 3.4ghz 16gb PC & NV...
xeltros
Sep 01, 2014Apprentice
you may be limited by either the NAS or the powerline adapter. Those things tend to never get their full speed and global performance vary depending on installations. Direct cable is always the best, but I think that if you got powerline in first place this is not possible. You could either use a better powerline adapter or use wifi N or AC if possible.
look at real throughput for powerline adapters : http://www.smallnetbuilder.com/lanwan/p ... harts/view
NV+ is not the fastest NAS on the market either. You could connect it to your PC to see the max speed (just give the two devices fixed IP on the same range), that way you'd know what you can squeeze out of it.
Jumbo frames could work, but your router/switch has to support it too, and given your computer I expect you to do something else than browsing the web, jumbo frames may increase the ping in games for example.
