clingon
Sep 01, 2014Aspirant
Speeding up data transfer?
My ON NETWORKS PL200-199UKS 200 Mbps Powerline (connected a D-Link DSL-3680 router) is feeding a tp-link tl-sg1008d gigabit Ethernet switch, which is hooked up to my Lenovo i7 3770 3.4ghz 16gb PC & NV...
xeltros
Sep 01, 2014Apprentice
Could you try to unplug the powerline adapter from the switch ? letting only cat6a cable on gigabit interfaces on it ? It should probably do nothing but I'd like to make sure that the switch doesn't use the weakest internet to set his other ports (never seen this before but...).
Couldn't find anything saying that you workstation had gigabit (didn't search for long I agree, still the techsheet didn't mention it...). Are you positive that this is a gigabit interface ? did you install the right driver for it ?
Have you done the direct connect test ?
you are right, everything passes by the switch the other hardware doesn't really matter, here the only things interesting are the switch, the NAS and the PC.
