sdinjens
Nov 19, 2011Aspirant
Spin down seems not to be working after firmware update
Hey there! I'm using a ReadyNAS NV+ and use it mainly for simple dumb storage, torrenting, and backups, nothing real complicated. For this reason, power consumption and noise pollution is importan...
sdinjens
Nov 21, 2011Aspirant
Thanks maxblack for the tip. It seems unlikely to me that they wouldnt be compatible, since both drive types advertise being power and sound efficient.
I've scanned the log, but don't really see anything I think should be relevant here. What should I be looking for exactly? Thanks for the help so far!
Heres the log:
Heres the log:
***** smartctl output for hdc *****
smartctl version 5.36 [sparc64-unknown-linux-gnu] Copyright (C) 2002-6 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: WDC WD5000AAKX-001CA0
Serial Number: WD-WCAYUH527677
Firmware Version: 15.01H15
User Capacity: 500,107,862,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Mon Nov 21 22:16:27 2011 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (8880) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 90) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 144 142 021 Pre-fail Always - 3800
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 619
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3811
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 11
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 10
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 608
194 Temperature_Celsius 0x0022 115 102 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
ATA Error Count: 18 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 18 occurred at disk power-on lifetime: 9 hours (0 days + 9 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 51 01 00 00 00 40 Error: ABRT
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
b0 d6 01 e0 4f c2 40 00 10:02:34.339 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 10:02:34.181 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 10:02:34.024 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 10:02:33.868 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 10:02:33.710 SMART WRITE LOG
Error 17 occurred at disk power-on lifetime: 9 hours (0 days + 9 hours)
b0 d6 01 e0 4f c2 40 00 10:02:33.552 SMART WRITE LOG
Error 16 occurred at disk power-on lifetime: 9 hours (0 days + 9 hours)
ec 00 01 01 00 00 a0 00 10:02:33.372 IDENTIFY DEVICE
Error 15 occurred at disk power-on lifetime: 9 hours (0 days + 9 hours)
Error 14 occurred at disk power-on lifetime: 9 hours (0 days + 9 hours)
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
***** smartctl output for hde *****
Serial Number: WD-WCAYUH655485
ATA Version is: 8
Local Time is: Mon Nov 21 22:16:28 2011 CET
been run.
data collection: (9000) seconds.
command.
power-saving mode.
recommended polling time: ( 91) minutes.
1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 142 140 021 Pre-fail Always - 3875
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 757
9 Power_On_Hours 0x0032 095 095 000 Old_age Always - 3812
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 746
194 Temperature_Celsius 0x0022 111 101 000 Old_age Always - 32
Error 18 occurred at disk power-on lifetime: 10 hours (0 days + 10 hours)
b0 d6 01 e0 4f c2 40 00 10:02:36.158 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 10:02:36.000 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 10:02:35.844 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 10:02:35.687 SMART WRITE LOG
b0 d6 01 e0 4f c2 40 00 10:02:35.529 SMART WRITE LOG
Error 17 occurred at disk power-on lifetime: 10 hours (0 days + 10 hours)
b0 d6 01 e0 4f c2 40 00 10:02:35.371 SMART WRITE LOG
Error 16 occurred at disk power-on lifetime: 10 hours (0 days + 10 hours)
ec 00 01 01 00 00 a0 00 10:02:35.191 IDENTIFY DEVICE
Error 15 occurred at disk power-on lifetime: 10 hours (0 days + 10 hours)
Error 14 occurred at disk power-on lifetime: 10 hours (0 days + 10 hours)
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** smartctl output for hdg *****
Device Model: ST2000DL003-9VT166
Serial Number: 5YD5SFF3
Firmware Version: CC3C
User Capacity: 2,000,398,934,016 bytes
ATA Version is: 8
ATA Standard is: Not recognized. Minor revision code: 0x29
been run.
data collection: ( 612) seconds.
command.
power-saving mode.
recommended polling time: ( 1) minutes.
recommended polling time: ( 255) minutes.
SMART Attributes Data Structure revision number: 10
1 Raw_Read_Error_Rate 0x000f 117 100 006 Pre-fail Always - 161607680
3 Spin_Up_Time 0x0003 091 090 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 39
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 060 060 030 Pre-fail Always - 1069005
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 391
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 8
183 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
184 Unknown_Attribute 0x0032 100 100 099 Old_age Always - 0
187 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
188 Unknown_Attribute 0x0032 100 098 000 Old_age Always - 42950328330
189 Unknown_Attribute 0x003a 100 100 000 Old_age Always - 0
190 Unknown_Attribute 0x0022 070 067 045 Old_age Always - 521469982
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 7
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 39
194 Temperature_Celsius 0x0022 030 040 000 Old_age Always - 30 (Lifetime Min/Max 0/21)
195 Hardware_ECC_Recovered 0x001a 021 020 000 Old_age Always - 161607680
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 188845417038114
241 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 172611295
242 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 1012428249
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** smartctl output for hdi *****
Serial Number: 5YD5RQVP
ATA Version is: 8
Local Time is: Mon Nov 21 22:16:29 2011 CET
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 116 100 006 Pre-fail Always - 115519912
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 641096
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 374
188 Unknown_Attribute 0x0032 100 098 000 Old_age Always - 25770196998
190 Unknown_Attribute 0x0022 072 070 045 Old_age Always - 487915548
194 Temperature_Celsius 0x0022 028 040 000 Old_age Always - 28 (Lifetime Min/Max 0/21)
195 Hardware_ECC_Recovered 0x001a 020 017 000 Old_age Always - 115519912
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 278146377056549
241 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 20777326
242 Unknown_Attribute 0x0000 100 253 000 Old_age Offline - 600779155
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
