sdinjens
Nov 19, 2011Aspirant
Spin down seems not to be working after firmware update
Hey there! I'm using a ReadyNAS NV+ and use it mainly for simple dumb storage, torrenting, and backups, nothing real complicated. For this reason, power consumption and noise pollution is importan...
maxblack
Nov 22, 2011Aspirant
Correct, that would tell me that you did something on 10/26 that stopped noflushd from running. Have you done any reboots since then? If not, by all means do a System reboot. Oh, I'm running 4.1.4 atm so forgot something obvious: look in your processes.log to see if noflushd is running. Its command should look like e.g. "noflushd -v -n 15" for 15 minutes for example. Even if it is there in your logs, I would try a reboot.
sdinjens wrote: The last entry matching noflush were succesful spindowns on Oct 26. After that, no such entries appear. Am I correct in assuming this means no spin-down attempt has been made?
It seems you are using your NAS as a DHCP server, and gizmo .36 wants to renew its lease every 4 hours (why I dunno, since 28800 is 8 hrs afaik?) but you certainly have your spin-down set for less than 240 minutes, yes? I don't use DHCP but doubt it requires a Read operation on your HDDs which will cause a spin-up.
Also, I notice you've not put a proper time server into the ReadyNAS clock setting; it's not affecting spindown but you should do this right anyway (unless your NAS is not connected to the 'net).
