cgehansen's avatar
cgehansen
Follower
May 15, 2013
Squeezebox not connecting to LMS on reboot
Hi, I have a problem with LMS. When my Duo boots up after its timed overnight shutdown my Squeezebox can't connect to it unless I reboot my router (Linksys 4200) and restart the squeezebox reciever. This happens every time but once it's connected again its fine. It used to work OK but the problem started a few weeks ago when the power was cut off from the Duo by accident. Does anyone know what I should do to fix it? Any advice appreciated.
1 Reply
  • When you reboot, does LMS see your squeezebox?
    Also does the Duo have a connection through your router to any other machine and/or the Internet. Is this connection ok when it restarts?
    What happens if you only reboot the router?
    Have you tried reinstalling the duo firmware and LMS?
ProSupport for Business
