Retired_Member
Aug 27, 2011Squeezebox radio and Readynas problem
Hi all, I am fairly sure that there is an answer to my problem, I just can't find it! I have a Readynas Ultra 2 plus with the latest version of SqueezeCentre (installed correctly using squeeze c...
sphardy1
Aug 27, 2011Apprentice
Mysqueeszebox.com is primarily for those who do not run a local server - use one or the other, not both simultaneously (which as you've found you cannot)
