Retired_Member
Aug 27, 2011Squeezebox radio and Readynas problem
Hi all, I am fairly sure that there is an answer to my problem, I just can't find it! I have a Readynas Ultra 2 plus with the latest version of SqueezeCentre (installed correctly using squeeze c...
Bud1
Jun 15, 2012Aspirant
sphardy wrote: Mysqueeszebox.com is primarily for those who do not run a local server - use one or the other, not both simultaneously (which as you've found you cannot)
I don't think that's strictly true. I have had the to cohabiting for years with no problem, until recently. I believe the local server passes of the squeezebox [or other device] connection to mysqueezebox.com, but the local server signs you on to mysq......com.
In my case it can no longer do that because the set up page returns "invalid user name or password". But if I direct my browser to mysque....com I can log on with no problem using the same id and password. Its an incredibly frustrating new "feature".
BTW, feel free to help if you have any knowledge regarding this enhancement. :(
