Retired_Member
Aug 27, 2011Squeezebox radio and Readynas problem
Hi all, I am fairly sure that there is an answer to my problem, I just can't find it! I have a Readynas Ultra 2 plus with the latest version of SqueezeCentre (installed correctly using squeeze c...
bokenrosie
Jun 26, 2012Tutor
Could it be that the two are out of sync? I have been running a local server (Ubuntu), a Buffalo (stripped down squeezeserver), and mysqueezebox and I find that when you switch between mysqueezebox and either of the servers it looks at the firmware level. If they are in sync it works fine, if not (or in the case of the Buffalo Linkstation where they control when it gets updated) it forces a firmware update to the squeeze device.
