theluke79's avatar
theluke79
SSH Configuration reset on reboot
Hi lads,
I have just freshly reset my RN102.
There is a bug that is annoying me terribly, every time I reboot the system the SSH configuration is messed up / lost, somehow it is being reset.
I follow this site to setup 2fa http://www.howtogeek.com/121650/how-to-secure-ssh-with-google-authenticators-two-factor-authentication/ it works fine until reboot, than I loose connectivity since the ssd_config file is being overwritten.
Why is this happening? Why is the SSH conf file overwritten?
The only way to gain access again is restoring a former version of the aforementioned file using the indications here:
https://community.netgear.com/t5/Using-your-ReadyNAS/RESOLVED-Can-t-SSH-login-with-Root-and-admin-pass/td-p/961120
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Some config files we attempt to self repair. This is one of them.
    • theluke79's avatar
      theluke79
      Hi! Thanks a mil for the clarification, now, how do I avoid this behaviour? I need a hardened more secure SSH, what can I do?
      • FramerV's avatar
        FramerV
        Hi theluke79,
        I am updating the thread to give way to others in the community to reply to you. Thanks for sharing your comments.
ProSupport for Business
