mrmilo
Jun 11, 2012Tutor
sshd won't start
I'm a happy user of the ReadyNAS Ultra 6. Last month I updated RAIDiator from 4.2.20.[T32] to 4.2.20. I used to have ssh enabled. 2 weeks after the update I tried to login to ssh again but no connecti...
mdgm-ntgr
Jul 19, 2012NETGEAR Employee Retired
What add-ons do you have installed?
If the OS Re-install doesn't fix things:
Have you made changes to /etc/ssh/sshd_config? If so try the steps here: Restoring SSH Access
Are you still running 4.2.20? Do note that there is a newer firmware 4.2.21 (http://www.readynas.com/RAIDiator_x86_4_2_21_Notes). You might find it helps to update to this firmware.
Keep us updated on your progress.
