Anonymous
May 09, 2017SSL Cert not secure
The SSL cert (to manage NAS) was good until I changed the NAS from "local users" to "Active Directory".
*The SSL Key Host is the IP address of the NAS, and the cert is still in the Trustede Root Certification Authorities for Chrome
Firmware is 6.7.1
I have the same issue on a ReadyNAS 4312
Anyone have a suggestion on what I can check?
I suspect the IP address of the NAS changed after you generated the self-signed cert.
- Anonymous
nope, I access the NAS with the same static IP.
I have the NIC's bonded, with 1 IP...and I just checked and its the same IP as the SSL Key Host
- Anonymous
This is an issue for Chrome. I was able to add the cert in IE...and it was fine. I was also abel to use Edge and it was fine.
*it seems Netgear needs to add something to the cert for Chrome to "recognize" its valid.
