geoldr
Apr 10, 2015Tutor
SSL Certificate
Hi all I know the way to bypass the SSL security thing by importing the certificate manually, but I am wondering why we have to do this? My NETGEAR Router does not have this issue, just the ReadyNA...
Apr 13, 2015Guru - Experienced User
That fixes a different problem. Netgear cut back on the root certificates they installed a few releases ago, which resulted in breaking the cert trust chain for several apps and user-installed tools.
geoldr wrote: I wonder if in 6.2.3 they fix the SSL issue.
From the beta page:
Add full ca-certificates bundle to fix apps that use HTTPS.
