Polaris1980
Oct 03, 2015Aspirant
Standard settings shares does not give full access
Hi
I have a Readynas Ultra 6 with RAIDiator 4.2.22.
Recently I had to do a factory reset. Now I am reconfiguring the NAS. I got stuck creating the shares. I read several topics on the matter; but this was not helping.
My goal: I just want to add a share with unlimited acces, so no restrictions for all (it is just me anyways).
The problem:
I add a share by filling in the name and description. I keep the "public access" checked.
As I interpreted the guidance from the internet; this should just be enough to optain goal.
But; when SABNZB downloads something; it does not give me access to the sub folder (I can enter the share, see the downloaded folder, but cannot access it).
Sab NZB does have full access (download; unpak in different share)
My question is; what setting do I use when I want my laptop and my media player to have full access?
On the CIFS configuration page:
Default Access: Read/Write
Allow Guest Access: checked
Advanced CIFS Permission
Automatically set permissions on new files and folders. checked
When new files are created over CIFS...
Group rights: read/write
Everyone rights: read/write
When new folders are created over CIFS...
On Advanced Options:
Share folder owner: nobody
Share folder group: nogroup
Share folder group rights: read/write
Share folder everyone rights: read/write
Grant rename and delete privileges to non-owner of files: checked
- Polaris1980Aspirant
Hi
Thanks for your reply
Unfortunatly that did not do the trick.
I see the share in windows, I can open it; but the folder it should download is not accessable.
The funny thing is; after that did not work; I also checked" Set ownership and permission for existing files and folders to the above settings. This option is ueful in cases where you are changing security level and you need to workaround files access problems".
This then works for all excisting folders. But after I make new ones; I need to do that again.That is not a desired option.
Did you ever came across this issue? Any thoughts on what I am doing wrong? Any help is appreciated.
Or is my NAS software broken.:smileyfrustrated:
