kiiilden's avatar
kiiilden
Start all over
hi there..
if i want to put in a new harddisk in my Readynas duo, which allready got movies on. Will they be deleted when i start the nas or will it just install the os and dont delete anything?
  • i thought i should do it before insert it :s
    this is the initial drive. i had a 320 gb in it before it put the 2tb in ..
  • StephenB's avatar
    Is RAIDar detecting the NAS at all?
    You can try removing the drive, connecting it to a Windows PC, and deleting all volumes on the drive with Windows Disk Manager (right-click computer, select "Manage"), and inserting it again. Deleting the volumes will return the disk to an unformatted state.
    I deleted the volumes and tried again, and now its up and running :)
    Thx alot StephenB !
ProSupport for Business
