tcsmedes
Jun 22, 2015Aspirant
Static IP changes Admin Password
I have a ReadyNAS 102 running the 6.2.4 firmware. If I set set my unit to use a static IP Address, when it goes to reconnect to the web page I get the prompt to log back in I provide the username and...
Jun 22, 2015Guru - Experienced User
What static address are you assigning, and what dhcp address is your router supplying?
Does your router support address reservation? If so, that is a better way to go.
