technique
Dec 20, 2022Aspirant
Stop running resynchronisation.
Hi. I have some question about resynchronisation on ReadyNAS 4312, OS 6.9.6. On the 15 november 2022 after an an unmanaged reboot of the nas, some errors on disks sda2 pops on the logs. A ...
Dec 20, 2022Guru - Experienced User
technique wrote:
This resynchronisation is a reconstruction of the volume, isn't it ?
It's a reconstruction of one disk in the volume (using the parity+data blocks on the other disks).
technique wrote:
Can we stop this running resynchronisation with no risks ?
Generally no, the volume will remain degraded if you do. If you know which disk is causing the problem, then it would be safe to replace that disk - especially since you are running RAID-6. But it is not completely without risk.
technique wrote:
Why does she start alone with a faulty disk and no disk replacement ?
Can i see the logs of this resync by command line ?
Downloading the log zip file is probably the best place to start. mdstat.log should give some info on which disk is resyncing. system.log, kernel.log, system-journal.log should have some information on disk errors.
technique wrote:
Can i replace the faultly hard drive in hot swap just after stopping the resynchronisation ?
What is the best process to perform disk replacement in this case with the minimum of risks.
I normally recommend hot-swapping (NAS running). You do need to be careful to identify the correct drive.
- techniqueDec 22, 2022Aspirant
Hi and thank you for your feedback.
I will replace the drive tomorrow (hot swap).
For the logs since the disk is in error, we cant donwload logs from the web page. We will check from command line.
Next week for the feed back
Thank you
- StephenBDec 22, 2022Guru - Experienced User
Have you tried? The logs are stored in the OS partition, which is replicated on every disk. The web page performance is slower during a resync, but it should still work.
If you use the command line, then for most logging events you need to use journalctl.
- techniqueDec 23, 2022Aspirant
Hi.
The nas was completly unresponding and the download off logs never works. The reboot doesn't work too.
After the disk replacement the logs download works. Now the volume is degraded and run a clean.
