Reefergeezer
Jun 26, 2011Aspirant
Streaming to iPad 2
Hi, I'm running a ReadyNAS Duo on firmware 4.1.7 (which is the latest version, apparently) and iTunes v 10.3.1.55. I have the ReadyNAS set up to act as an iTunes Streaming Server, and the scan h...
sphardy1
Jul 09, 2011Apprentice
Not a dumb question at all
The simple fact is that Apple has only very recently enabled iPads to be able to stream music from a server - that all falls under "AirPlay" which unfortunately is a different, though similar, technology to the sharing method used to make your NAS appear in iTunes under "Shared" on your computers. It's unfortunate because the iTunes Server included on all ReadyNAS devices is not AirPlay compliant, and iPads can only stream from an AirPlay server.
There is development in the open source community of a replacement application for the iTunes Server that Netgear use that is AirPlay compliant, but:
1. It'll never be ported to your Duo (too many unsatisfied dependencies)
2. Even porting it to x86 based ReadyNAS is a major task - again due to dependencies
Bottom line - Netgear is severely behind its competition in this area and because they never communicate their plans we have no idea if they are even working on some solution to this.
Your only alternative is to consider installing an app on the iPad that can stream from one of the other ReadyNAS services. For example, I have a couple of Logitech Squeezeboxes which I can control from my iPad via the SqueezePad or iPeng apps, both of which will play the media on the iPad too. I have seen references from others using DLNA client apps so that they can stream from ReadyDLNA which appears to work well - search the forum for more info.
