Ripperoo
Aug 22, 2013Aspirant
Struggling With Low Speeds < 15MBps Over Gigabit
Hey Guys I have been having a major PITA regarding transfer speeds ever since I purchased my 'ReadyNas Ultra 4 Plus' in May 2011. Originally, I was only getting approx 5-6 MB/second and came to...
Aug 24, 2013Guru - Experienced User
You can also use NAStester 1.4, which will do a timed drag and drop for you. There's a download link here: http://www.808.dk/?code-csharp-nas-performance
It seems reasonably accurate.
Disabling jumbo frames of course would not change the ping results MTU test. It just tells the devices not to use jumbo frames.
Did you also reset the MTU to 1480 on the NAS and in your NIC settings?
