Ripperoo
Aug 22, 2013Aspirant
Struggling With Low Speeds < 15MBps Over Gigabit
Hey Guys I have been having a major PITA regarding transfer speeds ever since I purchased my 'ReadyNas Ultra 4 Plus' in May 2011. Originally, I was only getting approx 5-6 MB/second and came to...
Ripperoo
Aug 24, 2013Aspirant
StephenB wrote: You can also use NAStester 1.4, which will do a timed drag and drop for you.
I'll check that out soon.
StephenB wrote: Did you also reset the MTU to 1480 on the NAS and in your NIC settings?
Every time I change the Jumbo Frames setting on the NIC, I also do the same on the ReadyNAS. The MTU on the ReadyNAS is automatically altered between 1500-9000 when selecting/deselecting Jumbo Frames.
