Ripperoo
Aug 22, 2013Aspirant
Struggling With Low Speeds < 15MBps Over Gigabit
Hey Guys I have been having a major PITA regarding transfer speeds ever since I purchased my 'ReadyNas Ultra 4 Plus' in May 2011. Originally, I was only getting approx 5-6 MB/second and came to...
Ripperoo
Aug 27, 2013Aspirant
StephenB wrote: Testing with the broadcom part is also an important next step.
So, I disabled the Intel NIC and re-enable the Broadcom NIC
I'll add my network speed tests findings using the Broadcom NIC as I go, but so far the ping result was
C:\Users\XPS-8300>ping 192.168.1.2 -f -l 1403
Pinging 192.168.1.2 with 1403 bytes of data:
Packet needs to be fragmented but DF set. x3
Ping statistics for 192.168.1.2:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\XPS-8300>ping 192.168.1.2 -f -l 1402
Pinging 192.168.1.2 with 1402 bytes of data:
Reply from 192.168.1.2: bytes=1402 time<1ms TTL=64 x4
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
As you can see, the pinging up to 1402 was was OK, but I got the 'Packet needs to be fragmented but DF set' message when I went above that figure.
