Soccerman18
Sep 02, 2015Aspirant
Stuck on IP 192.168.168.168
I have a ReadyNAS Ultra 4 Plus, after a recent power outage every time the NAS powers up it has the IP of 192.168.168.168. Every other device connected to the router is working correctly. I tried p...
Soccerman18
Sep 03, 2015Aspirant
I had only one cable plugged in, tried moving it to the other port but no luck there.
I was able to set it to a static IP and now I'm able to access the drive again. Thanks! I'm curious though, it's been working for years getting its IP from the router, why would that suddenly stop working?
JennC
Sep 03, 2015NETGEAR Employee Retired
Hello Soccerman18,
It seems it could not get an IP address from the network.
If you want to troubleshoot further to know what would have caused it, you may try doing soem problem isolation first. Like, if the NAS is connected to a switch (and switch is connected to a router), connect the NAS straight to the router and see if the same problem that it won't acquire a valid IP address from the network.
Please note that 192.168.168.168 is the default IP address of the NAS, if it does get an IP address from the network it automatically uses its default one.
You might also want to check if the firmware of the NAS is updated.
