ChunkySocks
Aug 26, 2014Guide
Stuttering video playback - help with troubleshooting
I have a ReadyNAS Ultra 2 running RAIDiator 4.2.26 - the video playback from the ReadyNAS is fine for about the first 30 seconds or so then both the video and the audio starts stuttering. Sometimes th...
vandermerwe
Aug 26, 2014Master
How did you stream to your laptop?
Did you use dlna?
Did you go through your router?
What model of Panasonic player are you using? Is it's firmware up to date?
The bottleneck is likely to be the Panasonic, not the readynas.
Did you use dlna?
