ChunkySocks
Aug 26, 2014Guide
Stuttering video playback - help with troubleshooting
I have a ReadyNAS Ultra 2 running RAIDiator 4.2.26 - the video playback from the ReadyNAS is fine for about the first 30 seconds or so then both the video and the audio starts stuttering. Sometimes th...
ChunkySocks
Aug 26, 2014Guide
Thanks for the swift replies.
It seems to play a few frames, stop, then start and play a few frames, then stop etc.
Not that I can discern, it doesn't sound like it's overexerting itself and when I was attempting to troubleshoot it from my laptop, FrontView seemed to respond fine although I can't remember if I was using FrontView whilst playback was being attempted.
Not sure, how do I find that out? The router is a Virgin Media Superhub (made by Netgear I believe). Are all ethernet cables equal or is it worth checking them? I think but can't be sure that they are all Cat5 cables, can check but if it's a network setting or dependent upon the router then... dunno, not sure what I'm talking about tbh.
Don't know - it's a Panasonic Viera TX-L37U3B
ReadyNAS > router > laptop (all connected via ethernet cable)
Good point, no, opened and played the file on my laptop using VLC.
Yes.
BluRay Disc Player DMP-BD75
Don't know, will have to check and look although it's possible, I vaguely recall doing something whilst messing about with the settings ages ago when I connected it up to the router. If updating the firmware is more involved than simply selecting an option after it's connected up to the router via ethernet then no.
OK, if it is, that could be the least worst option to fix.
Thanks again for both your posts.
readysecure1985 wrote: Is your TV buffering after that 30 seconds or does it just play part of the file and then stop?
Does the ReadyNAS seem really busy?
What kind of network are you using, 10/100 or Gigabit networking?
Is TV also gigabit or 10/100?
vandermerwe wrote: How did you stream to your laptop?
Did you use dlna?
Did you go through your router?
Yes.
What model of Panasonic player are you using?
Is it's firmware up to date?
The bottleneck is likely to be the Panasonic, not the readynas.
