dsm1212
Nov 25, 2014Apprentice
subsonic problem: ffmpeg in 6.2.0 distribution
The updated ffmpeg in the 6.2.0 distribution is: Version: 7:2.3.5-netgear1 It's super that this got updated, but unless I'm misunderstanding something it was built poorly. Subsonic is not transcod...
dsm1212
It seems that ffmpeg is actually being deprecated in debian 7. We should be switching to use avconv. But there is a convoluted set of dependencies in the current netgear distribution that prevents me from installing libav-tools which contains avconv. Doing so would uninstall a pile of important stuff and I'm wary of doing so. But quick solution:
Download 64-bit static build of ffmpeg from here: http://johnvansickle.com/ffmpeg/
Remove whatever you have in /apps/subsonic/transcode
Unpack the static tar into /apps/subsonic/transcode
(If it creates a subdirectory move the files up a level so that ffmpeg is in the transcode directory.)
steve
steve
