Sandshark
Sep 28, 2019Sensei
Successful memory addition to RR2312
If anyone is looking to upgrade the memory in an RR2312, I have successfully done so using a SK Hynix 4GB DDR4-2133 PC4-17000 ECC Memory HMA451R7AFR8N-TF DIMM, which is 1.2V. I suspect just about an...
wdolson
Jan 21, 2020Guide
Based on your post I went looking for memory. I'm not familiar with Hynix, but I found Crucial CT16G4RFD4213 16 GB on NewEgg for $52.95. They have 4, 8, 16, and 32GB versions. The 4 and 16 are around $52, but the other two are more expensive. I bought the 16 GB, popped it in and it worked fine. My system now has 18 GB of RAM.
It took some searching to find out how to tell how much RAM the system sees. It appears the only way to see this is to get to the Logs page, download the logs ZIP and look at the memory log.
This post was the only thing I could find on the net saying anything about how to upgrade the RAM in the RR 2312.
Sandshark
Jan 22, 2020Sensei
Thanks for the additional info on the larger RAM expansion. I'm not sure why Netgear has not made more information publicly available on this subject.
I used dmidecode from SSH to find out the RAM configuration, but you do need to install that package first.
- wdolsonJan 22, 2020Guide
When I was searching for information I did see somewhere someone said Netgear used to recommend expansion memory, but they quit because some memory makers changed the specifications of memory modules and reuse the same numbers sometimes and it became a mess.
