Sandshark
Sep 28, 2019Sensei
Successful memory addition to RR2312
If anyone is looking to upgrade the memory in an RR2312, I have successfully done so using a SK Hynix 4GB DDR4-2133 PC4-17000 ECC Memory HMA451R7AFR8N-TF DIMM, which is 1.2V. I suspect just about an...
Sandshark
Jan 22, 2020Sensei
Thanks for the additional info on the larger RAM expansion. I'm not sure why Netgear has not made more information publicly available on this subject.
I used dmidecode from SSH to find out the RAM configuration, but you do need to install that package first.
wdolson
Jan 22, 2020Guide
When I was searching for information I did see somewhere someone said Netgear used to recommend expansion memory, but they quit because some memory makers changed the specifications of memory modules and reuse the same numbers sometimes and it became a mess.
