Ionitor
Dec 22, 2011Aspirant
Swapped temperatures in recent Raidiator releases
I posted this in a different thread (at http://www.readynas.com/forum/viewtopic.php?f=24&t=43886&start=105) but realized after-the-fact that it was probably the wrong forum to bring it up, so I'll rep...
ahpsi1
Dec 22, 2011Tutor
Interesting. I have a Pro running 4.2.20-T15 and enclosure.log reports:
with Frontview showing:
Same from an Ultra 2 Plus running 4.2.19:
Now I'll update the Ultra 2 Plus to 4.2.20-T19....
So the Ultra 2 Plus didn't swap the values but the Pro (which was already running T15) was already (potentially) swapped. I'll try a downgrade to 4.2.19 on the Pro....
No Good, try 4.2.16 (no enclosure.log so this is from NASHerder's raw RAIDar response):
Now 4.2.26 -> 4.2.17 -> 4.2.18:
I'll check my Ultra 6 when I get home. So far this hasn't been as helpful as I'd hoped...
temp!!1!!status=ok::descr=56.0C/132.8F::expected=0-65C/32-149F
temp!!2!!status=ok::descr=26.0C/78.8F::expected=0-60C/32-140F
Temp SYS 57 C / 134 F [Normal 0-65 C / 32-149 F]
Temp CPU 25.5 C / 77 F [Normal 0-60 C / 32-140 F]
temp!!1!!status=ok::descr=74.0C/165.2F::expected=0-80C/32-176F
temp!!2!!status=ok::descr=37.0C/98.6F::expected=0-65C/32-149F
Temp CPU 76 C / 168 F [Normal 0-80 C / 32-176 F]
Temp SYS 37 C / 98 F [Normal 0-65 C / 32-149 F]
temp!!1!!status=ok::descr=46.0C/114.8F::expected=0-80C/32-176F
temp!!2!!status=ok::descr=31.0C/87.8F::expected=0-65C/32-149F
Temp CPU 47 C / 116 F [Normal 0-80 C / 32-176 F]
Temp SYS 32 C / 89 F [Normal 0-65 C / 32-149 F]
temp!!1!!status=ok::descr=51.0C/123.8F::expected=0-65C/32-149F
temp!!2!!status=ok::descr=23.5C/74.3F::expected=0-60C/32-140F
Temp SYS 54 C / 129 F [Normal 0-65 C / 32-149 F]
Temp CPU 24.5 C / 76 F [Normal 0-60 C / 32-140 F]
temp!!1!!status=ok::descr=52.0C/125.6F::expected=0-65C/32-149F
temp!!2!!status=ok::descr=25.5C/77.9F::expected=0-60C/32-140F
Temp 1 57 C / 134 F [Normal 0-65 C / 32-149 F]
Temp 2 26.5 C / 79 F [Normal 0-60 C / 32-140 F]
temp!!2!!status=ok::descr=24.5C/76.1F::expected=0-60C/32-140F
