Ionitor
Dec 22, 2011Aspirant
Swapped temperatures in recent Raidiator releases
I posted this in a different thread (at http://www.readynas.com/forum/viewtopic.php?f=24&t=43886&start=105) but realized after-the-fact that it was probably the wrong forum to bring it up, so I'll rep...
ahpsi1
Dec 23, 2011Tutor
On my Ultra 6 I see:
under 4.2.19. Prior logs suggest at least in my case the values have been swapped at least as far back as 4.2.17-T2 (no enclosure.log before that though I do have logs before that):
But what is odd is in this ^ log's enclosure.log (from 04/20/2011) there is no mention made of temp 1. Temp 1 does not make an appearance until 4.2.17:
All I can conclude is the CPU and SYS fans are plugged into the wrong ports on the motherboard in some units.
temp!!1!!status=ok::descr=10.0C/50.0F::expected=0-65C/32-149F
temp!!2!!status=ok::descr=28.0C/82.4F::expected=0-60C/32-140F
Temp CPU 9 C / 48 F [Normal 0-65 C / 32-149 F]
Temp SYS 28 C / 82 F [Normal 0-60 C / 32-140 F]
temp!!2!!status=ok::descr=27.0C/80.6F::expected=0-60C/32-140F
temp!!1!!status=ok::descr=14.0C/57.2F::expected=0-65C/32-149F
temp!!2!!status=ok::descr=30.0C/86.0F::expected=0-60C/32-140F
