Ionitor
Dec 22, 2011Aspirant
Swapped temperatures in recent Raidiator releases
I posted this in a different thread (at http://www.readynas.com/forum/viewtopic.php?f=24&t=43886&start=105) but realized after-the-fact that it was probably the wrong forum to bring it up, so I'll rep...
Ionitor
Dec 28, 2011Aspirant
After getting cacti up and running, I'm noticing that the temperature labeled as CPU is much more responsive to load than the one labeled SYS (which stays mostly constant regardless of load). So, I'm starting to suspect that the SYS reading is correct, and maybe it's being taken at a particularly hot spot on the motherboard.
