jimbobin's avatar
jimbobin
Swapping disks between ReadyNas NV+ v1 (RND4250) and v3 (RND4000 v3)
Hi All,   Just wanted what people thought of what i would like to do: I have a working RDN4250, can I power off the device and pull out my working drives and put them into RND4000 v3, power it on ...
  • StephenB's avatar
    Nov 21, 2016
    jimbobin wrote:
    Hi All,
    I have a working RDN4250, can I power off the device and pull out my working drives and put them into RND4000 v3, power it on and expect everything to work as it did in the orignal unit?
    I understand that both of the units are ReadyNAS NV+
    many thanks
    James
    They are both NV+ v1 ( http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/ ).
    You can migrate the disks that way.  Though it is best to put in a scratch disk first, and install the same firmware you have running on the 4250 onto the 4000.  If the firmware in the flash doesn't match the disks, then the NAS will install the flash version to the hard drives (either upgrading or downgrading).
    I am wondering why you want to do this (since the 4250 is working ok)?
