fatkid1974
May 01, 2016Aspirant
Switching from MBR to GPT
Firmware version 4.1.14. I am trying to backup my NAS data to a 4 TB drive. Because the NAS is setup using MBR partitioning table, only 2 TB of my usb drive is viewable. Will formatting and using ...
- May 01, 2016
4.1.x systems don't support GPT formatting at all - so that will not work.
May 01, 2016Guru - Experienced User
- fatkid1974May 01, 2016Aspirant
Thanks for the info. Time to upgrade I guess.
- StephenBMay 01, 2016Guru - Experienced User
Yes. Though USB performance on the duo is very slow, so you'd get faster speeds connecting the USB drive to a PC and copying over ethernet.
I'll have to try that, The initial backup was painfully slow. When hooked up to server drive shows full 4 TB, close to it anyway. Will I be able to write to the whole drive backing up over network? Or will I still be limited to only 2 TB.
