fatkid1974
May 01, 2016Aspirant
Switching from MBR to GPT
Firmware version 4.1.14. I am trying to backup my NAS data to a 4 TB drive. Because the NAS is setup using MBR partitioning table, only 2 TB of my usb drive is viewable. Will formatting and using ...
- May 01, 2016
4.1.x systems don't support GPT formatting at all - so that will not work.
fatkid1974
Thanks for the info. Time to upgrade I guess.
May 01, 2016Guru - Experienced User
Yes. Though USB performance on the duo is very slow, so you'd get faster speeds connecting the USB drive to a PC and copying over ethernet.
- fatkid1974May 01, 2016Aspirant
I'll have to try that, The initial backup was painfully slow. When hooked up to server drive shows full 4 TB, close to it anyway. Will I be able to write to the whole drive backing up over network? Or will I still be limited to only 2 TB.
- mdgm-ntgrMay 01, 2016NETGEAR Employee Retired
So long as your PC supports GPT if the USB disk is connected directly to your PC you would be able to use the full 4TB of space. The NAS neither knows nor cares how the 4TB of network storage provided by the USB disk connected to your PC is made up.
