lamblu
Jul 20, 2017Aspirant
Sync shares between two Readynas
I am hoping to find an option to sync a sharefolder between two ReadyNAS units in separate locations. (one folder two places) Since I am uncertain how to ask this question, I am hoping someone can he...
Jul 20, 2017Guru - Experienced User
If you mean one-way sync, then rsync over ssh is one way. https://kb.netgear.com/29929/ReadyNAS-OS-6-Setting-up-a-backup-job-with-rsync-over-SSH
Resilio sync might be an option for two-way sync.
- lambluJul 20, 2017Aspirant
Just to be clear, .... I have an RN312, and RN314. I would like to store files on a share on the RN312, and have the same files on the RN314. The RN312 is on a local network, and the RN314 is remote.
- StephenBJul 20, 2017Guru - Experienced User
The link I posted above tells you how to back up the RN312 share to your RN314.
How do I determine Host and Login information?
