lamblu
Jul 20, 2017Aspirant
Sync shares between two Readynas
I am hoping to find an option to sync a sharefolder between two ReadyNAS units in separate locations. (one folder two places) Since I am uncertain how to ask this question, I am hoping someone can he...
lamblu
Just to be clear, .... I have an RN312, and RN314. I would like to store files on a share on the RN312, and have the same files on the RN314. The RN312 is on a local network, and the RN314 is remote.
Jul 20, 2017Guru - Experienced User
The link I posted above tells you how to back up the RN312 share to your RN314.
- lambluJul 20, 2017Aspirant
How do I determine Host and Login information?
- StephenBJul 21, 2017Guru - Experienced User
Normally you'd set up a ddns name for the remote router (for instance noip.com), and use that ddns name for the hostname.
Login credentials are up to you to set on the remote NAS.
- SandsharkJul 21, 2017Sensei
Another option is to use a VPN to connect them. I use ZeroTier.
