LeapingLemming
May 05, 2019Tutor
Synchronisation offline after RN104 upgrade to 6.10 from 6.9.5
After upgrading to 6.10, Readycloud no longer synchronises ... "Synchronisation Offline".
In the NAS admin page,, ReadyCloud is switched on, shows "Internet Available" and "Services Available" som...
- May 18, 2019
Fixed. This is the second major software glitch with this device that needed significant effort on my part to fix. I don't know what someone with no tech skills would do in this cuircumstance.
Anyway, ended up buying an external drive; backing everythng up; and doing a factory reset Restoring all the files now, but it definitely does synch again. Cost $200 for an external drive I don't need and I lost of good chunk of two weekends with a couple of evenings thrown in. At the expense of time with family.
LeapingLemming
May 10, 2019Tutor
Reinstalling the OS did not work. I also fixed a certificate error I was having on my browser, did nothing. I have rebooted, restarted everthing, turned cloud services on and off no luck. ReadyNAS shows this:
ReadyCloud looks like this
LeapingLemming
May 13, 2019Tutor
I find these errors throughout my readycloud logs:
This is in one
2019-05-13;11:41:40.4;[44632];[3];D;calculateHash Out with LogicException
2019-05-13;11:41:40.4;[44632];[3];E;Logic exception: Couldn't complete md5 hash calculation, exiting app...
This is in another
2019-05-13;11:59:17.9;[208];[4];E;Task <status> failed, reason: <>, system error: <System Error: The operation completed successfully. (0)>
2019-05-13;11:59:17.9;[208];[3];I;Syncing - Received status from server, remote cursor <0>, local cursor <0>, reset flag <0>
2019-05-13;11:59:17.9;[208];[3];E;Fail occured during syncing <Syncing - Error occured during pullig. Later we are trying pull again.>
- LeapingLemmingMay 14, 2019Tutor
My linux knowledge is poor to lousy I admit ... but when I did a "jobs" command in ssh, there are no jobs running. And when I do a "service" command I get these. Is all this OK? Anything missing?
[ - ] apache2
[ + ] avahi-daemon
[ - ] bootlogs
[ - ] bootmisc.sh
[ - ] checkfs.sh
[ - ] checkroot-bootclean.sh
[ - ] checkroot.sh
[ + ] cron
[ + ] dbus
[ + ] forked-daapd
[ - ] hostname.sh
[ - ] killprocs
[ + ] leafp2p
[ - ] lsyncd
[ + ] minissdpd
[ - ] mountall-bootclean.sh
[ - ] mountall.sh
[ - ] mountdevsubfs.sh
[ - ] mountkernfs.sh
[ - ] mountnfs-bootclean.sh
[ - ] mountnfs.sh
[ + ] nfs-common
[ + ] nfs-kernel-server
[ + ] noflushd
[ + ] procps
[ - ] rmnologin
[ + ] rpcbind
[ + ] rsync
[ - ] sendsigs
[ + ] snmpd
[ + ] ssh
[ - ] sudo
[ + ] udev
[ ? ] udev-mtab
[ - ] umountfs
[ - ] umountnfs.sh
[ - ] umountroot
[ + ] urandom - StephenBMay 14, 2019Guru - Experienced User
My service list is slightly different (no sudo):
root@RN102:~# service --status-all [ + ] apache2 [ + ] avahi-daemon [ - ] bootlogs [ - ] bootmisc.sh [ - ] checkfs.sh [ - ] checkroot-bootclean.sh [ - ] checkroot.sh [ + ] cron [ + ] dbus [ - ] forked-daapd [ - ] hostname.sh [ - ] killprocs [ + ] leafp2p [ - ] lsyncd [ + ] minissdpd [ - ] mountall-bootclean.sh [ - ] mountall.sh [ - ] mountdevsubfs.sh [ - ] mountkernfs.sh [ - ] mountnfs-bootclean.sh [ - ] mountnfs.sh [ - ] nfs-common [ - ] nfs-kernel-server [ + ] noflushd [ + ] procps [ - ] rmnologin [ - ] rpcbind [ + ] rsync [ - ] sendsigs [ - ] snmpd [ + ] ssh [ + ] udev [ - ] umountfs [ - ] umountnfs.sh [ - ] umountroot [ + ] urandom root@RN102:~#
- LeapingLemmingMay 18, 2019Tutor
Initentionally left blank. Actually the web site was playing up and I posed the same message twice.
- StephenBMay 19, 2019Guru - Experienced User
Not sure that you don't need it. If you care about your data, then you do need a backup strategy for it. RAID isn't enough to keep it safe (with any NAS).
