evena
Jan 26, 2014Aspirant
Synchronizing images between Android Phone,Tablet
Hello, I want to synchronize images on my Android phone, tablet, and Windows 7 PC. Using the ReadyNAS as a central repository. Is there an app that can do this. I know there is an app for ...
evena
Jan 27, 2014Aspirant
Ok, so I first looked at at syncness, but I couldn't verify that it is actually supported,
and will instead try to make sweet home work.
The first time I ran the installation I was able to connect to the I.P address, and
select Volume, whatever that is (some form of group).
It failed to create a test file.
However, when I now run the installation again I get
"Failed to access share. Did you
enable Windows File Sharing ? Check
user name and password?"
There is nothing in the logs that suggest anything
Has anybody used sweet home with readyNAS ?
any suggestions ?
Even
any suggestions ?
Even
