i-CONICA
Jun 07, 2017Guide
Syslog database running
Hi, I've a ReadyNAS RN104. 4x2TB WD Red drives. I've noticed it's got a MySQL database running on it, with one database called Syslog. There are two tables, one called SystemEvents and System...
Jun 08, 2017Guru - Experienced User
i-CONICA wrote:
So I've learned it's the rsyslog service that's default on debian systems since version 5.
The RN104 firmware doesn't include it though, so this must be something you installed.
i-CONICA
Jun 09, 2017Guide
As I'd never heard of it until investigating this, it's not possible.
It may have been installed as part of some plugin/app I've previously had installed though.
I've in the past had several apps installed. I've only got Transmission installed now.
I've cleared out all this rubbish and it's working perfectly. I had a message telling me that the root mount point is 85% full which shouldn't happen. This was the /var/lib/mysql directory mainly. It's now much clearer.
Are you sure no version of the RN104 software has ever had this? As the logs started in 2015... I'll have a look in my dump of the DB and see what the very first records look like.
- StephenBJun 09, 2017Guru - Experienced User
That is very possible.
cd //
find . -iname *rsyslog*
finds nothing. I checked on my RN102 and my RN526x.
- i-CONICAJun 09, 2017Guide
Ah. Looking at the logs, I see that around that time, I had the "Linux-dash" app addon installed written by "Slobberbone" on here. There's a chance that installs it...
I'll try to grab the package without installing it and see... If it turns out to be the case, then anyone who's had that app installed at any time might have a similar problem with a database getting out of hand.
