dtarin
Sep 17, 2016Luminary
System: Alert message failed to send.
I'm stumped on what's wrong with setting up SMTP details. Whenever I click "Send Test Message And Apply" I get the message: Unable to send a test message Cannot send a test message. Check ...
Sep 17, 2016Guru - Experienced User
What email provider are you using?
- dtarinSep 18, 2016Luminary
fastmail.com
No idea what's wrong with connecting to that account.
To get things working, I used gmail with similar settings. Even using an app password. Seems to work fine. I'd still like to know what that cryptic error code means - might help me figure out what's wrong with my fastmail connection.
- StephenBSep 19, 2016Guru - Experienced User
Maybe download the log zip file, and look for more details in there.
You tried both ports - 465 and 587? I imagine you checked your spam filter.
You can of course send it using gmail to a fastmail address.
- dtarinSep 21, 2016Luminary
Oh. I didn't realize the download zip had a lot more logs in there than just the one from frontview. The smtp.log in there has some clues. I will take a look when I have a chance. Thanks for that tidbit of info!
