CarlEdman
Jun 11, 2017Luminary
System Suddenly Very Loud
Recently I noticed that my NAS (Legacy Ultra 6 Plus, with upgraded CPU and memory, running 6.7.4), which until then had been near-inaudible except possibly during boots or shutdowns, had become very ...
mdgm-ntgr
Jun 11, 2017NETGEAR Employee Retired
What about on ReadyNASOS 6.7.5-T299 (Beta 1)?
CarlEdman
No change, unfortunately. http://i.imgur.com/tNWwlXC.png
- CarlEdmanJun 11, 2017Luminary
Opened up the box to see if there was anything awry internally, but found nothing except the orderinary amounts of dust which seem to accumulate in electronics. However, nothing felt as warm to the touch as the 50+ degrees centigrade reported for "System." Is it possible that it is this sensor which is miscalibrated?
- SandsharkJun 11, 2017Sensei
I am experiencing the same too-high system temperature on ProBE and Pro6 systems running 6.7.1. But the fans are not running much higher because of it with the "balanced" setting.
