Dewdman42
Aug 01, 2026Virtuoso
System: V+12 voltage in enclosure Internal is out of spec.
I started getting the following warning messages last night to my logs on my Ultra2 which is functioning as a backup to my other primary NAS: System: V+12 voltage in enclosure Internal is out of...
Sandshark
Aug 04, 2026Sensei
It could be that the circuitry that measures the voltage has an issue. If that's the case, you can just ignore it or make a change in the configuration so that it stops reporting it. Something could be dragging down the voltage, which would be irreparable.
But the external supply is still the most likely candidate. Have you tried another one?
Dewdman42
Aug 04, 2026Virtuoso
no I haven't tried that yet, I found another post on this forum from 2017 with the same problem that tried your suggestion but they said it didn't fix the problem. Doesn't mean its not worth a try though at some point...I agree..
The error hasn't shown up again yet since the other day...so part of me is wondering if some kind of power drop happened that either got through my UPS or caused by the UPS...though my other NAS didn't complain.
Will watch it a while to see if it comes up again.
Do you know how I can manually check the current value, without waiting for a log message? is there a cmd line command I can use to find out current voltage?
